i was wondering if there was a way to burn a DVD and with the extra space left on the burned DVD burn MP3 files (so both the video and music files could be read by a dvd player)?
Regards
Does your dvd player support mp3 files on dvd media??? If so then it may work, it depends if you can switch to mp3 file mode if a dvd-video is detected.
To mix dvd-video and data files on a dvd you just add the mp3 files to the root dvd folder or create a new folder. Some dvd-video authoring tools supports this or else you choose to author the video to a dvd folder and later burn with for example nero and choose dvd-video, add the video and then add the data files(mp3) to the root folder or a new folder.
Very Mixed Requirements
By juliam in forum Newbie / General discussionsReplies: 7Last Post: 5th Jul 2011, 00:15 -
Authoring a mixed-media/resolution Blu-ray?
By jbigfoot in forum Authoring (Blu-ray)Replies: 4Last Post: 20th Jun 2010, 22:37 -
Mixed Multi Angle DVD Encoding Problem
By werdna1900 in forum Video ConversionReplies: 3Last Post: 11th Jun 2009, 05:32 -
How to make a mixed DVD
By Baldrick in forum User guidesReplies: 60Last Post: 4th Sep 2008, 14:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
