    Sep 2001
    Portugal - Europe
    One thing i'm having problems now is this... i have about 2 Gb of files in SVCD with 2 audio tracks (one is japanese and the other is english) in my HD... but i canīt seem to open them with any program i have... not even flaskmpeg... i really dunno why... what should i do to convert them to divx... and most important of all to be able to make two files... each one with a diferent audio track...
    Thanks in advanced.
    Jaa
    Gant
  2. Member adam's Avatar
    Sep 2000
    You should be able to open them in any demultiplexor. Use TMPGenc and go to file/mpeg tools and to the demultiplex tab, not the simple demultiplex. After you load your file you should see the video and 2 audio streams. Doubleclick on each of the streams and save it separately. Now go back and multiplex each of the streams how you see fit, although it might be best to just encode all streams separately.
