For the best video quality, what I should and should not select, in TMPGenc for the best video quality.
For VCD and SVCD.
I want to put an end on those terribles blocks that appears in black or dark images.
English in not my native language, so give me a brake.
I assume you are authoring a "Standard VCD"
Select the neccessary VCD profile using the wizard.
Enable Noise reduction.
Goto "other settings" and set motion search precision to High Quality.
Under GOP structure uncheck "Detect Scene Change"
Under "Quantize Matrix" select MPEG Standard profile.
Select "Soften Block Noise" with values as 55 x 55
That's it. This should give good results even with poor quality
noisy source. But be aware that it's almost impossible to get
rid of blocks at standard VCD bitrates (cbr 1150).
If you have lotsa high motion scenes, play with "Detect Scene Change"
till you get the best results.
Also, don't forget to check out some excellent VCD/SVCD templates in the Tools section.
-Keith
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 23:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 10:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
