I'm simply looking for a card that can do the following:
Encode in MPEG-1 mode in real time at higher resolutions than 320x240..let's say 640x480
I know some card do it in MPEG-2 mode but I really need MPEG-1...
I have a winfast 2000 and Iv'e just done a small test at the settings you want, and it played back ok for my eyes. Maybe others will see it differantly. Hope this helps.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
I just bout a canopus MVR-1000...it cost 700$ US and it can't even capture at higher resolution than 320x240 in MPEG-1 mode. It can only do it in MPEG-2.
Are you sure you card can do it and in REAL time? -
Maybe Iv'e got it wrong. I'm not 100% sure what you mean by "real time"
I simply recorded it on to my hard drive and played it back in WMP to check what it looked like. Can one of the OLDIES on the forum explain it to me?"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
By REAL TIME I mean, you put the DVD in the dvdplayer, you start the capture and it encodes directly to MPEG in real time. You don't have to capture and then encode. It captures directly to MPEG.
Data translation Broadway can do MPEG1 realtime, check capture link on left. The link is www.b-way.com Broadway Pro DVD is their newer board.
It will capture in realtime to mpeg1 via their input ports on the card. Just connect your dvd player output port to the Broadway input port
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
