Closed Thread
Results 1 to 10 of 10
  1. yes someone sent me the catch me if u can movie, suppose to be 3 discs anyhow its in the format of .bin and .cue... vcd format can anyone help me to buring this movie.. i dont care if its all on one cd or 3... or show me a guide plz
    -ganJa
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
  3. no one can help me?
    -ganJa
  4. zippyp, where can i get a text-editor... so i can configure the .cue files?
    -ganJa
  5. Far too goddamn old now EddyH's Avatar
    Jan 2003
    Soul sucking suburbia! But a different part since I last logged on.
    Brevity, for once:
    Needs 3 CDRs.
    Get CDRWin (or any other prog that can handle .cue / .bin, like latest Nero version or VCDEasy)
    Load the .cue file. It will automatically set it all up and find the .bin file.
    Press burn.
    Well, that's how it's *supposed* to be done, errors and omissions excepted
    -= She sez there's ants in the carpet, dirty little monsters! =-
    Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
    Dec 2002
    The Great Northwest
    The think the latest version of DVD Decrypter will do .bin but you have to go to settings and make sure it is check. I do not do any VCD/SVCD so if this irrelevant to your problem please ignore post.
    3.1.6.0
    http://www.dvddecrypter.com/
    Dd
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  7. For any CUE/BIN image that has multiple tracks (which VCDs innately are), do not use ANY program that burns directly from the BIN file without reading the CUE file -- it will probably not work properly.
    To burn a CUE/BIN image, use CDRDAO/VCDEasy, CDRWin or the latest versions of Nero.
    If something fails with the CUESHEET, open it up in Notepad and read the first line (which contains the path to the BIN file). If the PATH is wrong, then fix it and try again.
    If you are using CDRDAO/VCDEasy, make sure that both the CUE and BIN files are in the same folder, have the same name and that you don't use long filenames.
    If the CUE file is just screwed up, you can regenerate a new CUE/BIN image by using the CUE/BIN regenerator tool in GNU VCDImager Tools GUI: http://www.michaeltam.com/vcdimager_tools_gui.html
    http://www.vcdeasy.org has some more ideas on burning CUE/BIN images if you still have problems (mounting it as a virtual CD with daemon tools and then using something like CloneCD is a good idea).
    Regards.
    Michael Tam
    w: Morsels of Evidence
  8. okay i got this much i got the configure your cue files.. and i understand how to load a disc image on nero and start to burn, but it asks for me to insert a cd+r not a dvd+r and i wanna burn it on dvd so i can watch it in dvd player. help me
    -ganJa
  9. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Do not discuss warez.
  10. ganJa: it is time for you to read http://www.vcdhelp.com/vcd
    VCDs must be on CD media.
    You cannot burn them onto DVD-R media.
    As long as your DVD player can read CD-R/W media (try an audio CD) then it should play VCDs on CD-R media just fine.
    From now on, please do some basic research on the topic first.
    Regards.
    Michael Tam
