I have a 2 year old Toshiba SD-4205 dvd changer. It is at rom revision 1.3
I can't play dvd+r or dvd+rw that I have burned slide shows to. I have tried different types of software. I have a new Plextor dvd+r burner that I am using to burn the dvds. These dvds play fine in my cheapo Apex. I am aware there is a newer firmware version available for the Toshiba SD-4205 player. Version 2.0 is available. What I need to know is if this firmware will allow dvds that I burn to play. Toshiba customer service does not guarantee anything. I hate to throw out this dvd player because it is built like a tank. It will play ripped cds, cd/rw and vcds with no problem. If I chance the 2.0 firmware, it is likely to cost $75.00 to do the upgrade at a local repair shop. Considering decent players can be had for $125.00, this seems like an expensive gamble. Anyone have this player and sucessfully had dvd+r work.
Bernie
Results 1 to 1 of 1
Toshiba sd-k780 DVD player does not play DivX
By van_d_man in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2009, 02:09 -
Toshiba HD-A2 pausing during play...advice needed.
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 8th Aug 2008, 02:27 -
I can't play a DVD-RW on my Toshiba D R-400
By WC in forum DVD & Blu-ray RecordersReplies: 3Last Post: 24th Jul 2008, 12:23 -
From HDV Camcorder to DVD to Play in HD DVD Toshiba HD A2 Player
By fjmr in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Jul 2008, 11:04 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40
