I plan to convert some VHS tapes to VCD with an old Celeron 466mhz w/ 384mb. I have both 7200 and 5400rpm HD's available to put in the system.
I need to get a video capture card of some kind, can this system support this? Some recommendations would be great.
I'm only using it to capture some class lecture material, so the quality isn't that great to begin with. I rather not move my new computer or the VCR into my room. So it would great if I can just use my old system that's just collecting dust.
thanks in advance
Video card capture may be too much for your system, but if you go the firewire route (Canopus advc-100 or MiniDV with analog conversion) it will probably work fine because then you are basically just doing a file transfer with very little processor load.
But it will take a LOOOOoooooonnnnggg time to encode to MPEG in TMPGEnc or similar software encoder. -
capture should work without too many problems - I had a Pinnacle DC-10+ in an old p2-300 that would capture without dropping frames.
but G-man is right - conversion on that machine is going to take a looooooooong time.
I would probably network it so you can transfer captured files to a beefier machine for editing and encoding, or make sure it has cd burner, and segment all your captures at 700Mb....
- housepig -
An option I have for conversion is transfering my files ton my external harddrive and converting them on my P4. So the conversion aspect shouldn't be a problem.
Are there any particular features I need to look for in a card? Or will any one w/ a video-in work. thanks in advance -
if you have any devices with an s-video out, get a card with s-video in.
if you want to export back out to VHS or another tape format (non DV) look for one with a video out.
it really depends on your budget. Check the Capture Cards section, look at the ratings on the card (you can search by Highest Rating).
Then look at the prices and see what gives you the most bang for your bucks.
I wanted something that was not tied to my graphics card, would accept s-video in, and was under $100. I ended up with the Aver DVD EZmaker card for $50, and I'm very happy with it. But if you've got $300 (or $500, or $2,000) burning a hole in your pocket, you can find great results at any price point...
- housepig
Computer video capture vs. vcr to dvd combo?
By Haopengyou in forum Capturing and VCRReplies: 24Last Post: 18th Dec 2015, 23:50 -
How can I use multiple usb video capture cards on one computer?
By gbenson in forum Capturing and VCRReplies: 0Last Post: 27th Jan 2011, 19:47 -
2nd best option to capture video to computer from Camcorder??
By Canes in forum Capturing and VCRReplies: 15Last Post: 10th Jun 2010, 06:17 -
Can I capture video on DV tapes and computer hard disk simultaneously ?
By AAC in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2008, 14:05 -
Newbie needs help..can't capture video from dig vid cam to computer
By lithnights in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 18:08
