hello all...i recently purchased an AVerTV capture card..and when i go to do a test capture the end result is a clear video with very low volume muddy audio. i am lost. i am using default settings NTSC and mpeg 1 for capture settings..any ideas?? i would like to add viewing the source (tv) with the card is great both audio and video
ASUS A7V133
512 mb pc 133
20 g hd
x-gamer 5.1 soundcard
i have also browsed and used the search function to no avail
well i tried 3 capturing programs and established it must be a setting for the recording that i have missed..any ideas?
i've updated the soundcard drivers, capture card drivers, mobo drivers (4n1), still nothing...anyone?
I just had a look at the Data Sheet for the AVerTV card - it's not obvious where it's drawing the sound from. Is it plugged into your sound card via a cable running from the TV card to Sound card?
If so it's probably recording the sound through the 'Line-in' on the sound card - check the volume level on the 'Line In'.
It may seem obvious but it needs to be mentioned. -
yes it's connected externally to the sound card through line in....oddly i was browsing reader reviews and found my answer.. a fellow had basically the same problem and was told somewhere the card has issues with certain soundcards and to use the mic jack instead....it works fine this way
What to look for in Video Capture/Software 4 newbie?
By rivrbyte in forum Newbie / General discussionsReplies: 16Last Post: 1st Mar 2010, 14:42 -
Newbie wanting to capture/re-author DVD from old and new sources...
By archaic0 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2009, 17:49 -
Newbie question: cannot view/capture older DV tapes
By sinbarambam in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Jun 2008, 08:48 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 15:36 -
Capture in segments...help for newbie!!
By wormdog88 in forum Capturing and VCRReplies: 0Last Post: 10th May 2007, 08:37
