I want to know how to encode .rm to .avi or .mpg in TMPGEnc. I have tried EO Video and hate it, it hasn't worked once for me. I use to TMPGEnc and would really like to encode useing that. Can anyone help me??
Results 1 to 13 of 13
There is a gem out there called Real7ime.
It can do .RM and limited .RMVB.
Give it a try.
If you are doing .RMVB, you might have to extract the audio seperately,
as desycned audion may crash Real7ime.
Enjoy!
R. -
And you can find this where, even though i would rather be able to use TMPGEnc.
Hey . . .
You can find it at www.geocities.com/real7ime - seems to run ok under W2K (but haven't tried it on my XP box at home yet).
Cheers,
B.===============================
"Don't ask for my specs - click the b*&^dy button . . ."
This is just to encode from off the web. I have the files I want to encode files I have.
EO-Video does it. The trial last 20 days and has no limits.
eo-video.com
Convert Real to WAV/AVI/MPEG1/MPEG2
Then dump the converted file into TMPGenc if you still need to.
The EO conversion is very good.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
I only make it with tinra and the gui.
I convert the rm to avi and then I encode to mpeg.
Almost always, I use some filters with virtualdub before.
No audio Lipsynch probs that way, frameserving gurante some stuff, but make the whole proccess slow -
Well as I have been saying tinra didn't work and I have not had good luck with EO Video.
okie dokie peoples...
i have found away 2 do this... fist of all get rid of your real players...
this is what you need:
(1) real player alternative
(2) codecs (these 2 you get from the kazaa lite web site and that is http://www.kazaalite.tk/
(3) rawaverecoder
(4) TMPGEnc
All you do is extract the audio using (3) then open (4) and well you know the rest... and there you go...
It works i was at my wits end till i tried this and now i'm happy... please if this works for you to please post this on other websites so everyone else can benifit from it... -
(3) rawaverecoder
(4) TMPGEnc
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
