I ripped a movie with smartripper and would like to burn to dvd. What software do I need to burn the files created by smartripper? I have Nero and CopytoDVD, but I haven't figured out how to get them to work. If I just stick the files in the Video_TS menu created by Nero, will this work?
Yes you need to put all the files into a VIDEO_TS folder then burn that folder however most DVD's the file size is going to exceed the limits of the DVD+R or DVD-R disc you're trying to backup. Just download and install DVDshrink which is a free program then use it to compress the files to fit onto a single DVDR. Look for the DL link on this site sorry I don't have the link to post for you.
Actually, it's just the movie files so the total size is 3.5gb. I assume this will fit, unless Nero adds a bunch of stuff. I'll try it and see.
DVD Upconverting for a ripped movie
By mario595 in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2010, 01:41 -
need your help on BD ripped movie on Panasonic BD60
By yd8552 in forum Blu-ray RippingReplies: 2Last Post: 2nd Nov 2009, 15:50 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 18:18 -
ripped DVD plays, but won't burn
By Yes, me in forum MacReplies: 7Last Post: 3rd Sep 2009, 03:58 -
A little help can't seem to burn this movie after ripped to HDD
By f-zer0 in forum Authoring (DVD)Replies: 4Last Post: 10th Apr 2008, 21:13
