hi all , quick question .. i have started to make a lot of multi films.
have made my own menue screen with dvd menue studio and everything works like a dream, menue comes on screen , select ether film and off it plays...
BUT... to be a bit flash i would like a dolby trailer to play first then the menue screen to come up
i can get the dolby trailer to play ,but then the menue screen dose not come up ... ANY IDEAS![]()
In connections set your trailer to first play, then set the end action of the trailer to point your title menu.
DOH....
god i am thick, i used to do it that way when i put a dolby trailer infront of the main film.....
one of the probs now with these easy progs like dvd2one , u 4get how u used to do the films in the old way
anyway disturbed1 , u r a star
THANKS
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 20:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
