My dvd player wont play pal vcd's is there any way to convert the pal mpeg to ntsc
did a divx pal to ntsc over the weekend. Load up a VCD ntsc template in TMPG, change any of the specifics you'd like, but also under the SETTINGS, ADVANCED, check 3:2 pulldown. This did the trick for me. There's some horizontal lines on occassion, but you're gonna have some loss as you're going from 23 fps to 29.97 fps.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
