hi,
Ive ripped a dvd with, Dvd decrypter and shrunk it with dvd95copy.
now what ? Ive tried using IC but this doesnt run properlly on my machine.
What can i use instead to burn the outputted fils fron win95copy?
thanks![]()
Cybernology.co.uk
I think he's looking for a freeware option. Check out the "Author" link to the left for different methods to burn DVDs. You should have a VIDEO_TS folder with your newly transcoded video in it right. What I normally do is:
1) Run IMGTools to make an ISO/IMG image file of the VIDEO_TS folder (http://www.doom9.org)
2) Burn the image file with DVD Decrypter
Have never made a coaster with this method and both programs are freeware. -
thanks fir the replies.
I do have RecordNow Max but was unsure how to get the outputted files on to the blank.
im a bit confused, dvd95 copy, stuck aload of files in to a folder i created.
thanksCybernology.co.uk
burning software
By hardy in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 18:00 -
Best Burning Software
By bmoreravyns in forum Authoring (DVD)Replies: 32Last Post: 14th Oct 2008, 20:46 -
Best burning software???
By Eternal7331 in forum DVD RippingReplies: 8Last Post: 11th Oct 2007, 00:29 -
what burning software?
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Oct 2007, 17:48 -
burning software
By Cmonteith in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 19:07
