No matter what AC3 codecs/filter I install all GSPOT ever shows is -
[/img]
how can I get the AC3 codec installed ?
I am using Win2k and trying to install the Moonlight Odio codec 1.23.
Help anyone ?
It might help if you actaully type the error. Your IMG tag doesn't work unless you can put your image on an HTTP server.
Impossible to see the future is. The Dark Side clouds everything... -
I have installed the Moonlight odio dekoda but when checking a file under gspot it says codec NOT installed. Under View > Installed codecs > audio the following dont have a format tag and I'm sure Moonlight Odio should have a 0020 tag ??
DMO WMAudio Decoder DMO qasf.dll
DMO WMSpeech Decoder DMO qasf.dll
DSH AC3Filter ac3filter.ax
DSH Moonlight Odio Dekoda mlcom.ax
DSH MPEG Audio Decoder quartz.dll
DSH InterVideo Audio Decoder iviaudio.ax
DSH MPEG Layer-3 Decoder l3codecx.ax
DSH Windows Media Audio Decoder msadds32.ax
DSH ACELP.net Sipro Lab Audio Decoder acelpdec.ax
Installing 32bit AAC ACM and AC3 ACD codec on Windows 7
By pchan in forum Software PlayingReplies: 3Last Post: 26th Apr 2012, 14:53 -
Wrong Codec ??? (for DTS to AC3 conversion) Please help!
By KushSmoka420 in forum AudioReplies: 4Last Post: 29th Dec 2011, 07:50 -
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 15:42 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 17:57
[/img]
