Hi!
I can't get DivX-movies to play properly on Windows XP, often the sound is very corrupted. it the framrate is very bad.
Some have any idéas on which coed to use on WinXP?
/L
I'm no expert on DivX and don't have Windows XP, but isn't the "problem" more likely to be in the audio codec. Isn't DivX 3.11 just a video codec.
If you dont use them already try the Radium MPEG Layer-3 audio codecs when encoding to DivX. I've recently started to use the DivX4 codecs which I find excellent.
regards
eSATA not hotpluggable with WinXP?
By PartingShot in forum ComputerReplies: 6Last Post: 13th Sep 2010, 19:59 -
WinXP SP3 Problems
By bevills1 in forum ComputerReplies: 5Last Post: 1st Aug 2010, 22:48 -
WinXP Thumbnail Change
By Anakha in forum DVD RippingReplies: 1Last Post: 19th Feb 2010, 10:44 -
DivX playback problems on Philips DVP 3040 (since installing WinXP SP2)
By mikester2 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Nov 2007, 12:54 -
problems with v2.5 install on winxp
By welthqa in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Aug 2007, 16:37
