  1. Hi,
    I have authored a DVD, and I want to add software so that when I put it in a computer, it will autostart my software, but obviously still play (the DVD) in a DVD player. Has anyone done this before? Thanks!
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    The only program less than thousands that I know that does this easily
    is called SPRUCE UP...
    When you go to output to DVD (this program will never be updated as SPRUCE is now a MACINTOSH company)you can only write to PIONEER
    A03 or other 1st generation drive..
    so...instead chose write TITLE SET TO HARDDISC DRIVE, by going to advanced options...there is a checkmark called DVD ROM CONTENT..
    This when checked, allows you to hi-light a FOLDER that will be re-written to the DVD VOLUME ON HDD next to the VIDEO_TS and AUDIO _TS..
    THEN BURN WITH NERO and ignore the error message nerogives when it see this folder and claimsthe dvd will be non-compliant..
    IF THE PROJECT plays backfromthe video_ts onthe harddrive...,despite this,nwero will makea set top playabledisc..of course..you gottaq put it in a computer to use the PROGRAMS you put ion that "OTHER CONTENT"folder
  3. So, what other programs (that can cost 1000's) will do this? Anyone know if the upcoming adobe DVD authoring package will do this? THanks!
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    I think the third one is what you need
    Nero 5.5 - Complete Features
    Supported formats
    DVD:
    DVD ISO
    DVD UDF
    DVD ISO/UDF (Bridge)
    Bootable DVD
    DVD Copy on-the-fly and via image
    DVD images
    CD:
    CD-ROM
    CD-ROM XA
    Audio CD
    Mixed-Mode CD
    Video CD
    Super Video CD
    CD Extra
    Bootable CD
    HFS
    ISO/HFS Hybrid
    UDF
    UDF/ISO Bridge
    Dec 2002
    The Great Northwest
    Scenarist, I think also has ROM production capabilities. What is it going for now about $30.000.00us or so?
    Dd
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
