I have encoded a number of WAV files to AC3 using Besweet. Problem--when played back (either on the computer or receiver from the resulting DVD), the "sound level" (sorry, I don't know the correct term) is a lot lower for the AC3 file vs the WAV file. I have tried the "auto gain" button in the Besweet GUI, but the results are the same. To get a satisfactory sound, you really need to crank the volume level up on the receiver.
I think I've seen earlier posts regarding this problem, but no resolution. Anyone with similar problems and more importantly, a fix?? Thanks in advance.
try ac3machine which uses besweet. http://www.doom9.org/ac3machine.htm
i think i had to check 'audio find maximum gain' -
its a known problem:
http://forum.doom9.org/showthread.php?s=&threadid=33535SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
BeSweet for 4.0/quad AC3?
By RogerTango in forum Video ConversionReplies: 1Last Post: 17th Nov 2011, 04:16 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
No Audio when encoding with AC3
By Stankia in forum AudioReplies: 2Last Post: 25th Apr 2008, 19:44 -
AC3 dialnorm encoding
By RobinReumers in forum ffmpegX general discussionReplies: 0Last Post: 6th Jun 2007, 10:35
