Hello! I am still debating on whether or not the AVERDVD capture card would give me better capturing (less dropped frames) over the ATI AIW 128 Pro tuner card (using MMC 7.7) which I currently have. I have not started to capture yet since I just got done putting together my system.
Can I get a vote based on your experiences as to which one I should use to capture my old 8mm tapes based on my system configuration. I also heard that AVERDvd can capture in realtime for MPG2?
Any suggestions would be highly appreciated.
TIA.![]()
Thanks and regards,
RayBan
ATI 9600 Pro; Abit BH7; P4 2.4Ghz 533; 1G PC2700 DDR; Toshiba SD5002 DVDR; WD 120G 8MB 7200 Capture Drive & 160G 7200 Program Drive; Pinnacle Studio 9 and Nero6 -
I wouldn't buy either one of them, if you're looking for good analog capture go with the Canopus ADVC-50 or ADVC-100, they are the best consumer-level analog capture devices on the market today.
I haven't tried the ATI AIW, but the Aver card has me satisfied for analog capture.
I do find that I get better results capturing in .avi and converting to mpeg2 than I get from capturing directly to mpeg2, at least using the included NeoDVD capture app. (better meaning more definition)
- housepig -
I have a AIW 128 16mb and a avermedia tv stereo. Being able to use the btwincap drivers is a big plus with the avermedia. I use iuvcr to cap broadcast to dv.avi on the fly I have access to a dsr20 dv/dvcam vtr which would function like a Canopus dv bridge but I don't need to hassle with it. If you are uncomfortable dealing with making sure drivers stay current and your direct show filter priority doesn't get screwed up then any bt878 card is the way to go. If you aren't proficient at that, a dv camcorder or a canopus dv bridge might be the way to go. I'm getting ready to buy a 120gb hd so I'll be all huffyuv all the time and you can't do that with an analog to dv device.
Capture analog with camcorder or ATI card?
By Onceler2 in forum Capturing and VCRReplies: 7Last Post: 28th Nov 2009, 08:25 -
going CRAZY: capturing with ATI HD 3600 (analog)
By nuzumaki in forum Capturing and VCRReplies: 6Last Post: 13th Jan 2009, 18:24 -
Unable to transfer some VHS to DVD using AverDVD EzMaker PCI Card
By fromvn in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2008, 12:38 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25 -
1st Time Capturing - No Image - Aver EZMaker USB
By kmxe in forum Newbie / General discussionsReplies: 12Last Post: 13th Oct 2007, 10:43
