I have got a film which I play on my pc ok, the format is Avseq03.dat I put it in Nero used the wizard to convert it picked video 1 came up with cd1/ext/mpegav/segment/vcd/ I dragged the file over into the bottom part of Nero put a disk in and selected burn it came up with re-encde vid file which I did and started to burn it finished ok took it out would not play on p.c. or d.v.d. player can anyone please help or put me right to where I am going wrong I have used 4 disks up to now I am using (White Label) 80mins disks by prodisc, which I use for MP3s I am burning on AOPEN CRW1232 rewrite thanks for any addvice or help (maurice)
Look in the CONVERT section at left to convert the DAT to a MPEG then use a (S)VCD authoring program to burn the MPEG as a new (S)VCD. Make sure you know which type of video you have VCD or SVCD.
Panasonic DMR-ES45VS, keep those discs a burnin'
how to convert dvd to play pal
By Hermanngolfing in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2010, 16:21 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 20:23 -
How To Convert A 4:3 DVD To Play On A 16:9 TV
By MOVIEGEEK in forum User guidesReplies: 5Last Post: 24th Mar 2008, 09:02 -
Convert .avi to play on a DVD player
By Aaron1978 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2007, 13:06 -
Convert DVD to play on a PDA
By underwurlde in forum DVD RippingReplies: 2Last Post: 1st Jul 2007, 03:01
