Hi all
I have 2 questions:
1) is it possible to transfer an avi file into vcd without first converting avi moives that i have downloade from kaza to mpeg file? I know avi files had to be converted to mpeg 1 file, then convert them to vcd using nero. So my question would it be possible to skip conversion of avi file to mpeg file? if so can anyone please tell me how?
2) I have downloaded an avi file. However, when i played it using micrososft's media player, the video/picture became like scrambled tv movies. The audio is there and perfect, and the content is there, but the picture is scrambled. Does anyone know what seems to be the problem with the picture? if so please help me how to fix it.
Thank you
1.No
2.Check the codec and install it.
Downloaded files are normally littered with errors.
Try removing bad frames etc... -
Originally Posted by hardcoreruss
1. dont use nero to convert , basically its crap
2. codecs, you need them , goto tools on the left and dl all codecs
3. ive wriiten a smalle word doc to explain what to do to convert avi's to mpg ready to burn to vcd
www.data-uca.150m.com/vcdencoding.doc
just curious about this latest copy protection
By Seeker47 in forum Latest Video NewsReplies: 23Last Post: 24th Jul 2011, 18:55 -
curious about a video problem
By maca in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2011, 11:50 -
Curious problem. WMV to AVI no sound.
By sebblewich in forum Video ConversionReplies: 1Last Post: 3rd Jan 2011, 04:49 -
curious dvr-ms format and conversion
By todds1 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2009, 04:38 -
Curious about cause of this ghosting(?)
By kiwiusa in forum RestorationReplies: 12Last Post: 17th Feb 2008, 21:01
