  1. Site says new release, but all mirrors only have older version?
  2. Betanews now has it...
    Feb 2003
    Land of Oz
    Yeah, same problem dude. Download page looks promising, but actual file pointed to is the 702kb old version instead of the 753kb newie.
    Hopefully be fixed soon.
    The glass is neither half-full, nor half-empty.
    It is simply twice as big as it needs to be.
    Feb 2003
    Land of Oz
    Are you sure?
    The web page for BetaNews say 3.1.6, but the download is the old 702kb file (ie. 3.1.5). If you run the setup, it says 3.1.5.
    I just sent a PM to LIGHTNING UK! on his forums, so hopefully he will let the appropriate people know soon.
  5. Just got the 753kb file from BetaNews
    Feb 2003
    Land of Oz
    Yep, it is correct now. Filesize is 753kb.
  7. DVD Decrypter 3.1.6.0 (29/04/2003)
    Fixed DVDRAM support in ISO Write mode
    Fixed hangup when searching for devices on some machines
    Fixed destination folder / filename bug
    Fixed DVD+R disc finalisation problem
    Fixed PCM demux 'end of file' bug
    Fixed a bug in the first GOP patching code
    Fixed CSS cracking code
    Increased maximum software read error retry count to 50
    Added support for alternative chapter info file for DVDMaestro - using a ';' rather than ':'
    Added the option of forcing the program to use a given decryption key
    Added the option of using the 'Most Recently Used' folder as the default destination
    DVDDecrypter 3.1.6.0 released April 29, 2003 download mirror [753KB]
    http://www.mrbass.org/dvdrip/SetupDVDDecrypter.exe
