  1. Anyone know any free or demo versions of good storyboard software? I plan on using it only a couple of times. I would like it to have a little picture library thing, so I could just drag over images, and not have to draw them.[/quote][/code]
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    http://www.zebradevelopment.com/download.htm
    http://www.powerproduction.com/
    several others -- if you have a mac or linux system there is a free one also
    check the shareware listings on the net ,, there may be others cheaper than above apps ..
    pen and paper pretty cheap also
