  1. I made a backup of my Two Weeks Notice Disk using Instant Copy 7.2
    It looks fine but seems to default with the English Subs Turned on. You Have to go into the menus to turn them off. This is a Warner Disk and I've had issues before with them. Plus this disk has somewhat of a seamless branching feature linking the menu to the gag reel. I'm looking to try to find a method to fix this. Should I load the Movie only Ifo into Ifoedit, strip the subs, reassemble the entire disk and then feed it to Instant Copy ? Or is there a better method? I've had this issue before and always ended up just ripping the movie only in DVD2One, but I want to try to get around this with IC if possible.
    Any suggestions appreciated.
  2. Originally Posted by Scarpad
    The same thing for me, but the Warner movie is "Blood Work" and it is impossible to turn off subs. (Note: language italian and subs english ).
    Me too. Thanks.
  3. I used DVD2one to backup that movie and just didn't select any subtitles.
  4. Originally Posted by Bob W
    Are you able to keep original menu?
  5. Originally Posted by zanzarame
    I believe with the latest version of DVD2one you can keep the menu however I used the first version so no menu. That's not a big deal to me as DVD2one still keeps the chapter marks so I just use the remote to either go to the next chapter or I can enter the chapter number I want and go directly to it.
  6. Originally Posted by Bob W
    I believe with the latest version of DVD2one you can keep the menu ...
    Sorry, but i don't know dvd2one. It keeps menu, but strips extra (if i want to keep menu, video, 1 language and no compression or the smallest compression)?
  7. The same problem (all subs not stripped but, fortunately, not visible) with IC and "A few good man" dvd.
