I want to convert a 23,976 movie DivX to SvcD using virtualdub and tmpgenc. I frameserv and add sub via virtualdub to tmpgenc. In tmpgenc I set framerate to pal (25fps). In Virualdub I have tryed diffrent settings to get around this problem. I have done this many times with no prob. Any ideas??
/Ariddon
Have you turned on 3:2 pulldown
it's very easy to encode in 2 steps
1š must encode video -load *.avi in vdub / in VIDEO change fraterate to 25 and then frame serve (movie.vdr)
open tmpeg without close vdub and load the movie.vdr and encode using your template (only video) (try KVCD template)
video itīs done.
2š using vdub open *.avi and save audio (direct stream copy)
to encode audio must 1š use Besweet to make (audio.wav) ntsc2pal (23.976 to 25fps) and then using tmpg to encode to *.mp2
after just multiplex *.m2v and *.mp2 to finalmovie.mpg
so you canīt do video and audio at same time to avoid de-sync
2man -
The thing is that I have done this in on step before without this problem. 23.976 divx ->pal SvcD in tmpg. But I try this way. Cant I extract a CBR wav and convert it to 25fps and frameserv with 25fps to tmpg??
this worked for me when i was having the same problem
try this: https://www.videohelp.com/forum/viewtopic.php?t=119210
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
