First of all, THANKS, to Baldric and others for the great guides on getting backups of DVD created.
I have had absolutely no trouble getting DVD5 backups made. However, I've run into a snag with the DVD9. Everything seems to be fine until I use CopyToDVD to burn the finished IFO.
My burner (HP 100j) whirs along happily for about 20 minutes. Then, CopyToDVD changes from a progress bar to a "finalizing" bar. Then, the DVD pops out and an error log pops up on the monitor. It contains two messages - both are write errors - one is a specific zone. Needless to say, the disc plays nothing. Luckily, I am using DVD+RW.
But, I have no idea what causes the problem. I am going to try a different disc since I think that it most likely. If it is not the problem....Help!
Has anyone else had a similar problem? If so, did you fix it? If so, how?
I am using the trial version. I am hesistant to buy the program.
Does anyone have any suggestions for programs to purchase to burn the IFO you make with DVD Shrink?
THANKS!
Blu
I think I solved the problem. I have been able to burn now - in 20 minutes no less (originally the program said 1 hour). I simply re-ripped the disc, and it burned properly. I also used a new disc to burn to - so it could have been a media problem as well. I have been able to burn two more backups of DVD-9 without trouble. The only hiccup I've had since fixing the first problem seems to be faulty media.
Danke
Results 1 to 1 of 1
Saving DVD Disc Image for someone else to burn complete with autoplay&loop?
By wyclef in forum Authoring (DVD)Replies: 4Last Post: 11th Jun 2010, 00:07 -
Burning with CopyToDVD for DLP
By ckurowsk in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2008, 01:37 -
CopytoDVD Issue
By Cybrex in forum DVD RippingReplies: 1Last Post: 30th Jun 2008, 19:14 -
Error I get after I finish copying a dvd with copytodvd
By litzg5 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2008, 15:17 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28
