Very often files appear extremely dark on my monitor but are great when they're burned and shown on a tv.
I should be upgrading my monitor soon, it's too small. In the meantime, is there a way to increase the brightness, aside from the physical control on the monitor?
I appreciate any suggestions.
IF you have Adobe Photoshop or Photoshop Elements it comes with a built in Gamma corrector that will make your monitor as bright as you could possibly want it. After you install the program you can access it in the control panel under Adobe Gamma
If you do some degree of imaging/video work, that suggestion is highly recommended.
Most people don't have their monitors well calibrated at all and it is a definite requirement if you want to to get the gamma/contrast/brightness of your media clips right.
Regards.Michael Tam
w: Morsels of Evidence
MP4 messes up the brightness
By midnait in forum Video ConversionReplies: 4Last Post: 23rd Jun 2009, 13:27 -
Is 300 cd/m2 brightness good enough ?
By SingSing in forum Newbie / General discussionsReplies: 6Last Post: 12th Jun 2009, 23:17 -
sudden brightness jumps
By carmatic in forum RestorationReplies: 14Last Post: 24th Jan 2009, 12:05 -
Problems with brightness shifting
By Jerry1964 in forum EditingReplies: 5Last Post: 18th Oct 2008, 08:51 -
Avi change brightness
By Digiface in forum EditingReplies: 4Last Post: 9th Aug 2007, 18:15
