Maybe they have always been like that.
When I load the SVCD PAL VBR template in the wizard, under the Audio settings tab the bit rate is greyed out as 128kb/sec instead of 224. The CBR wizard has 224 audio.
How can I change the wizard audio setting just for the PAL SVCD template?
I may just have to load the CBR template then change it from CBR to VBR.
mine did the same thing and to fix that problem load up the 'unlock' template and it will allow you to change that to 224 again.
But the 128 only shows up when I load the a PAL SVCD with VBR in the project Wizard. A CBR PAL SVCD sets the audio to 224. When loading via the main window it also shos 224.
Just VBR PAL SVCD in Wizard is 128
I can't load the unlock template when in the wizard.
Tmpgenc 4 plug-in settings cant be changed?
By mrjust in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 22:50 -
FairUse Wizard, quantizer and codec settings
By 2dpikke in forum DVD RippingReplies: 2Last Post: 25th Feb 2010, 08:03 -
Fairuse Wizard settings - looking for rules of thumb
By JamesNG in forum DVD RippingReplies: 3Last Post: 29th Jul 2008, 20:01 -
settings for Womble MPEG Video Wizard DVD
By Vril-ya in forum EditingReplies: 0Last Post: 20th May 2008, 19:18 -
question about settings on Fair Use Wizard for best picture
By jimdagys in forum DVD RippingReplies: 4Last Post: 18th Oct 2007, 03:13
