I had a post bookmarked (I think) on how to fix this issue, but I can't seem to find it...can someone help me?
I have an ac3 file (192 kpbs/48 kHz) that is the sound file for a 6:48 second long VBR Pass2 movie that I have encoded. All the other capture/encodes worked fine out of this series except for one, where I am trying to fix the sync issue.
Unfortunately the originals have been deleted, so I don't have the original avi or the PCM Wav file to go back and look at....
the audio-sync issue is a very minute amount but noticable being that it is animation...
thanks for your help!
I know nothing of the original post, but assuming the sync is out by a fixed amount from the start and does not get progressively worse through time, then have you tried the latest BeSweet (the Beta, not the stable)?
I have not used it myself for this prupose, but I noticed it allows you to insert a lead-in time assuming you can figure out how many fractions of a second it is out.The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
It is a set amount... thanks for the info on BeSweet (I probably have an older version).
Any idea how I can determine what that offset is? -
No not really. This has always been a pain for me.
I try and "best guess" based on a key scene that has something featured that has a distinct sudden sound, but it takes ages to get right because it really is just trial and error. Would be interested to hear if anyone has a better method.
If your video & audio streams are huge you may want to shorten to something small so you can experiement quickly to find the offset before doing on the originals.
Have fun.The glass is neither half-full, nor half-empty.
Player that can play back m2v and ac3 files in sync
By cheerful in forum Software PlayingReplies: 2Last Post: 9th Sep 2009, 20:48 -
Demuxed VOB into M2V and AC3 -- Sync issues
By jj_30 in forum ProgrammingReplies: 0Last Post: 16th Jul 2009, 12:38 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
gotsent issue (cant find ffmpeg)
By X400 in forum Video ConversionReplies: 1Last Post: 6th Nov 2007, 02:59 -
M2V To Avi Conversion Issue
By R3bel in forum Video ConversionReplies: 2Last Post: 4th Sep 2007, 19:15
