    Feb 2001
    australia
    Which proggie should i use to get audio in WAV from the VOB files
    i have used dvd2avi
    looking for alternative
  2. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    i have used dvd2avi
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Why do you need an alternative? The above is a good way.
    In any case, I can think of two other ways:
    1. Load up your VOB file or VOB set with FlaskMPEG 0.6+ Choose the audio stream you want and then save it to wav.
    2. Use a DVD ripper to extract the AC3 stream from the vob files. Merge them. Then use a proggy like AC3Dec to decode it to wav.
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Mar 2001
    Virginia Beach, VA
    Use Vob2Audio
    extracts the sound as and .ac3, .mp3, or .wav
    can be set up for multiple bitrates, even variable..
    I use that as my preferred method to extract audio, and just use DVD2AVI for frameserving...
    hasn't failed me yet, and I don't have to worry about normalizing, and other crap... sounds better to my ears too.
    Mike
