I have a new Sony laptop -- stats should be in profile....
I want to put several 8mm (not digital) movies onto a DVD.
What is the easiest way?
I have heard that I can use a digital camera with passthrough capabilities will work. If so, which model? Will a Sony TRV350 work?
Or what do you recommend?
All suggestions welcome
thanks in advance
Judy
I would reccomend the Canopus ADVC-50, but since you're using a laptop I would have to go with the Canopus ADVC-100, it is a box with analog inputs and it converts the analog video to a digital signal then passes it to your computer through a Firewire port. I have only used the ADVC-50 wich has given me great results, but I have heard lots of good things about the ADVC-100 as well.
http://www.canopus.com/US/products/advc-100/pm_advc-100.asp -
If you are amateur and you are planning to upgrade your camcorder, DV camcorder with pasthrough and analog inputs will do same thing. You will save $300 buck toward better camcorder. If you are doing this profesionaly, then you should go with somethink like ADVC-100 that is designed and made just for that purpose.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
If I get the Canopus ... will it also work on transfer VHS to DVD -- and if so, do I run it through the VCR?
thanks
Judy
Advice for an Analog TV Tuner for broadcast.
By m33ts4k0z in forum Video Streaming DownloadingReplies: 5Last Post: 21st Jun 2009, 09:38 -
Problems with analog cable capture
By billqs in forum Capturing and VCRReplies: 2Last Post: 6th Apr 2009, 15:31 -
Analog capture poll
By goggy59 in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2009, 20:28 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18 -
AMiA - Video storage/repair ect. Advice Info
By StuR in forum RestorationReplies: 0Last Post: 10th May 2007, 12:26
