Hi, i was reading and found some interesting articles..
Is it possible to burn a DVD-R with a Regular CDR Burner?
If it is.. whats the method to do that?
Yes it is possible. Just stick a blank dvd in your cd writer and burn it.
Ahh i misread the topic, I thought that he was trying to burn a dvd type thing onto a cdrw.
If you want to burn a DVD-R with a CD-R/W burner, the answer is NO.
Regards.Michael Tam
w: Morsels of Evidence -
For a short clip...yes. Check out Mini-DVD. However, most standalone DVD players will refuse to play them. For an entire disk...no. You have to get a DVD burner. Start saving those pennies...
Originally Posted by troyvcd1The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
A CD-R burned with DVD data files is sorta like a DVD but it only holds a very short ammout of video and only a few DVD players can read them. You'd likely be better sticking with VCD or SVCD in that case.
Can't burn DVD using TDK burner
By tee jay in forum MacReplies: 7Last Post: 16th Sep 2008, 14:01 -
Is there a problem with my DVD Burner? Blank Disk after a Burn?
By nadizo in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 02:18 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:53 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 20:41
