I have been experimenting with capturing, editting and authoring using video studio 7. I have tried several different capture settings but the final dvd is not great. The best capture settings I have found are Frame size 352x480, Speed/Quality bar at 99%, Video data rate at 4500kpbs, 29.97 Frame rate, Field order A and MPEG 2. This has given me a watchable picture from my dvd but the picture is shaky at times. If you increase the playback speed on the dvd player the picture seems to be smoother which would suggest to me a frame rate problem but I can't seem to get the proper setting. I am capturing from vhs and I have an ATI 8500DV video card. Pentium 4, 2.4 ghz, 512 mb ram. Any suggestions? Thanks
4500kpbs that's the highest your program will allow you to go. I think you might want to look into a diffrent program that can handle a higher bitrate.
At 352x480 you should be able to get very good results at less than 3000 (I usually use 2700 in TMPGenc). Where is your source coming from; did you vidcam it or is it coming from VCR or Satellite? If the original is poor quality then you will have problems (GIGO).
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS to DVD to PC capture
By NYC Film in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2010, 18:06 -
Best settings for VHS Capture to MPEG2 for archiving...
By VinBob in forum Video ConversionReplies: 12Last Post: 12th Sep 2007, 06:14
