  1. I have added six seperate Mpeg2 files on the DVD. First I need a way of linking all of the Mpeg2 files together in order to play the first mpeg2 file and continue to the last, without going to the menu after each mpeg-2 file. Also How do I link a button called play to the first video and have it play all the way through to the last.
  2. Banned
    Mar 2003
    WI
    There is no way to do either of these in DVD Architect, all you can do is have a button for each Video and it will go to the main menu once that video is done playing. Most consumer level authoring programs like DVD Architect don't allow you to specify "end actions" for your title sets wich is basically a script that tells the DVD player where to go once it is done playing that video. Higher end software such a DVD Maestro and the one I use wich is a Sonic Fusion system will allow you to do this. But ones like DvdIt, MyDVD, Ulead DVD Factory, and DVD Architect will not allow you to do this.
  3. Thank you Sir for your Feedback!!! You have saved me a ton of time. I guess there is no way around it i am gonna have to learn maestro....
  4. Banned
    Mar 2003
    WI
    Yup, Maestro is actually a pretty simple program once you learn your way around it.
