I Have a capture card Pinnacle PCTV, i have tried a lots of software for realtime capture (MPEG 1,MPEG2) the Pinnacle software is very poor for it, and it VirtualDub i capture videos in DivX format. But now i have discover.. the WinDVDR, it is amazing software for realtime.
Good Settings for MPEG2 352*288+ 1800Bit+, the VCD format is also Good.
WinDVDR is the Best solution?
I tried both WinDVR2.0 and WinDVD recorder and WinDVR2.0 offers much better capture quality.
IUVcr is an excellant product, for capturing in AVI. You can use any codec you want. Interface isn't so good.
PowerVCR is just awesome in it's functionallity. Unfortunately you are stuck with MPEG1 or MPEG2 formats (but you can set the bitrates).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I use WinDVR with an Aver EasyDVD card . I use custom settings it caps great. Some of the best staight to mpeg2 video I've seen.
SeanWe all like Sheep have gone astray... -
Please somebody tell me how to get the WinDVR recorded shows to SVCD so that I can watch them on my DVD player. They record fine on the computer, but when I move the files to a CD, the DVD player says it is a non-playable disc. I know the player will play vcd, and svcd, because I am able to watch vids made using Pinnacle software from my Sony MiniDV. thanks.
tom_ragatz@rac.ray.com
tragatz@cox.net -
The Canopus ADVC100 works OK with windvr to capture straight to mpeg.
I haven't found a way to get the captured output to a vcd though.
The format seems to be different than what vcdeasy wants.
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 08:42 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
