I have a Sony camcorder (model DCR-TRV350) that comes with MYDVD, it has a USB connection and a firewire connection....
I have a homegrown PC that is the following:
2.4 P4 Intel chip
Albatron PX845E Pro II Motherboard
1 gig of PC2100 DDR Memory
XFX nVidia Geforce4 MX 440 64mb DDR Video Card
2 Western Digital 80gig harddrives
1 DVD-CD Reader (cheap brand)
1 Sony DVD Writer model DRU500AX
6 2.0 USB ports
but, no firewire port....
I want to copy my Camcorder home movies striaght to the Sony Writer....
can I just install a plain firewire port and MYDVD software will reconize this firewire port and write the movie right to the Sony writer??? It didn't reconize the USB port.
or, do I have to buy an expensive capture firewire board?
what I have done so far is download the camcorder movie via the image-station software and the USB cable provided by the Sony camcorder to an mpeg movie (what kind I don't know), then burned that onto the dvd with MYDVD software....but, the quality was poor, was that because I used USB to dowanload?? Also, it was a slow process for a 4 minute movie....I would much rather go right to the Sony DVD.
Any help would be great.![]()
Thanks,
rpgman
Since quality is a big issue for you, I would suggest getting a firewire card, as they start at around $15.00. Windows Media Encoder 9 is freeware and should fit your bill if you do not have a capture program that can capture firewire.
Also, you can capture directly to your DVD writer. Read this guide.Hello. -
so what your saying is:
your giving out 2 options....
1. buy a $15.00 firewire pci port that MYDVD or Windows Media Encoder 9 will use to write directly to the Sony DVD without any editing....correct?
2. Use Intervideo WinDVD Recorder(Free Trial Available)
but, it seems the quality wasn't as good doing that.
and I should burn these on what kind of DVD? DVD-R? or DVD+R?
Thanks,
rpgman -
Well, what I am saying is think about going ahead and investing in a firewire card, period. Then try a trial version of software that can capture DV from your camera using this card. Ulead has a programs, one which I use is Video Studio 6 which has DV capture mode, which I use to capture my DV from my Sony camcorder.
Or if you like capturing directly to your writer, go I would suggest going ahead and purchasing the firewire card and capturing the DV directly to your DVD writer.
I am afraid I must beg off the DVD-R vs. DVD+R debate, as I still use (S)VCDs, but the gurus here will be more than happy to address that portion of your question. Gentlemen?Hello. -
well, going to the pci firewire card worked...used Mydvd to go directly to the dvd....but, I have a question?
this might seem dumb, but I noticed that it took 280mg for a 4 minute video.....the dvd's hold 120minutes....am I right thinking I won't get 120 minutes to go on the dvd?
maybe I'm not doing the math right or something....280meg divided by 4 minutes is equal to 70mg....70meg times 120 minutes is 8400 meg or 8.4 gig right?
(280/4=70x120=8400)
is that right....could it be the 'quality'? and, the lesser quality, the more you fit on a dvd.
btw, Tommyknocker...thanx for your help!
thanks,
rpgman -
Correct.... for bets quality mpeg2 (around 8000 kBits/sec) you can fit around 60 min to DVD. You can fit more by lowering bitrate and loosing quality.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
thank you donpedro !
you guys are the best...
this site is the best for anything to do with dvd
keep up the great work !
rpgman -
I am using a DCRTRV340 camcorder for capture, I purchased a firewire card that came with Ulead videostudio5 and have not been having any trouble with them at all.
complete camcorder virgin looking for a (up to)$850 camcorder
By rocketman122 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Aug 2010, 11:34 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 04:09 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 13:47 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
