CANSOME GIVE US SOME INFO,I BEEN BURNING FLIMS WHICH COME IN THE FORMAT BIN + CUE ONTO CDR DISKS WITH NERO,I HAVE JUST GOT HOLD OF THE NEW SONY DVD WRITER,CAN SOME ONE TELL ME CAN YOU PUT ALL OF THE BIN +CUE FILES ONTO A DVD R DISK OR A DVDRW DISK ETC. BECAUSE SOME FLIMS CAN TAKE 3 CDR DISKS WHEN I BURN THE CUE FILES,CAN YOU PUT ALL OF THE CUE FILES ONTO ONE DISK AND HOW. : :P
THANKS
when you burn the bin/cue files then you have a vcd or svcd so follow the appropiate guides
you should follow a (s)vcd to dvd guide.
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=VCD+to+DVD&os...&search=Search
too big when burning with nero
By chief-1 in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 21:21 -
Burning DVD+R with Nero 7
By solarblast in forum Authoring (DVD)Replies: 6Last Post: 24th Aug 2010, 05:17 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 22:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35
