I ripped the audio off of a dvd using smartripper 2.41. It just gave me .vob files. How can I convert them into music files (.wav, .mp3, etc?)
Is there a simple program that will do this?
tia
a .vob has both audio and video intertwined.
check the Convert guides to find out how to de-mux (separate audio and video) a .vob (I believe that SmartRipper will de-mux, if you choose the correct settings).
Once you have the demuxed files, throw out the video file, and check in the Audio Convertor section of the Tools page for a convertor to get from that format to .wav.
(sorry if I'm being vague, I'm at work and I don't have SmartRipper on this machine, so I can't give you setting info...)
- housepig -
thanks for the info. In smartripper, I went to the streaming info and only shose the audio portions to be ripped. So the .vob files should all be audio.
I'll check the Audio Convertor section. I was just hoping someone could steer me in the right direction so I could get a program that would do the whole thing for me in the future.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 10:11 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
