Hey Guys, I'm not sure if i posted this at the right place, so if not i'm sory..
I just got my first DVD- burner Sony DWU10A which is prettty nice.. Know the question is i just got a burned dvd-r from a friend which i wanna make a copy without missing any quality of the disk.. can i do that with DVDschrink?
Just do a "disc-to-disc" copy using the DVD burning software that came w/ your drive. If your friend fit the data onto a DVD-R, then it will fit onto another DVD-R w/out the need for shrinking the size.
Am I missing the point of your question?
EDIT: By the way, since it's a disc to disc copy, it's all digital, no loss of quality -- you know, the whole point behind the DMCA, macrovision, Jon the DeCSS master, and all that? -
Why are you using dvd shrink? Just use DVD Decryptor to make an image of the DVD. THen use nero or anotehr burning program to burn it to a DVD. No need to use Shrink.
He doesn't even NEED DVD Decryptor if his buddy has already got it onto a DVD-R, unless it's somehow copy-protected...
Am I missing something here? I copy DVD-R to DVD-R with absolutely no problem using RecordNow, which came w/ my Sony 500UL drive... -
no Karate Media you are not missing anything at all :P
I'll give it a try with my DVD burning software that came with the driver.... :P If not could i use nero to make disk to disk? -
Yeah,
Barring any added hidden CGMS crap that the authoring software might put on, it shouldn't have ANY copy protection and so would be a straight Disc-to-Disc copy that EVERY disc burning app should be able to handle, incl. Nero, ECDC, etc.
Lots of times at work, I take video and record it into our Pioneer PVR-9000 as straight transfer. Do it a couple of times-diff shows, make menu text and finalize.
Then I take this and make a Disc Image w/ Nero and then burn 5, 10, 20, 50 copies. Easy as pie. And pretty fast, too.
Scott -
Most burning programs will have it...
BUT -- I did realize my one mistake: I have this unfortunate habit of thinking that everybody has exactlly the same setup as me! I use an external DVD burner, which means I have two DVD drives, so I can do disc to disc.
If you only had one DVD drive (the burner), then you would either have to save the files/folders to your harddrive first, or create an image to burn onto the blank DVD-R.
I'll try to keep my blinders off from now on!
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
