I have downloaded a file, where about half way through, the audio gets about 1 or 2 sec ahead of the video. I tried ripping the audio/video apart with Virtual Dub and then putting them back together with TMPGEnc, but that didn't work. I uncompressed the audio and tried again, but no luck. I tried speeding up the video bitrate, slowing down the audio bitrate and using the goldwave program, but still I can't get the audio and video to match up. Is it that the source file doesn't match, so I can't fix it or does anyone know another way I could try?
Thanks for any help you can provide.
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
