I have a small 2 min sound file that i would like to play on the main menu for a VCD im making, i know i can just create a VCD file with music and then put comands on it to do what a normal menu does, but i was hoping there is a way to keep the high res video file, its a still image, so no moving parts.
I dont really want to do the VCD Header Trick becuase some times it doesnt work, some times it does.
any help would be great!
Encode your still using VCDEasy (v1.1.5 is latest) then search the forum here for topic "VCD Stills with Audio" to show you how to add audio to the menu.
Hope this helps.../\/\ars /\/\ayhem -
I created two guides to combine a high-res picture with audio. Afterwards you have only to define in the PBC Navigation tab of VCDEasy the link to your files your are offering within our menu picture.
Jürgen
No Sound in Menu
By fian_nick in forum Authoring (DVD)Replies: 8Last Post: 29th Feb 2016, 08:10 -
PowerDVD 10 - Blu-ray sound OK, menu navigation OK but no image
By rilopes in forum Software PlayingReplies: 4Last Post: 10th Aug 2010, 11:16 -
Pinnacle Studio 9 sound on menu
By JaceKiwi in forum Authoring (DVD)Replies: 4Last Post: 29th Jun 2009, 03:31 -
[Vista] Sound file context menu/other issues
By Ai Haibara in forum ComputerReplies: 0Last Post: 4th Mar 2009, 02:40 -
Sound on Background menu but not on DVD chapters....?
By tikigod19 in forum Authoring (DVD)Replies: 10Last Post: 3rd Aug 2007, 20:14
