i have an ati radeon video card and i was wondering if i can connect to my standalone dvd to make vcd copies/ dubbing
Your really better off ripping the DVD and encoding that but to answer your question directly probably so.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You sure can, and it make's the movies in half the time. Just plug it in !!
vidio out to video in etc, be be aware you may come across the protection "Macrovision" I am sure you will find a way to get past that....
DVD recorder that will record video direct from SDHC card
By madtony in forum DVD & Blu-ray RecordersReplies: 16Last Post: 12th Apr 2009, 12:14 -
Can Easycap Video Grabber Capture card USB 2.0 RCA be used to record Beta
By laslim in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 11:06 -
How can I record without TV card?
By Xavier in forum DVB / IPTVReplies: 4Last Post: 17th Apr 2008, 07:58 -
The best card to watch/record HDTV?
By Chuck_Johnson in forum DVB / IPTVReplies: 31Last Post: 9th Feb 2008, 12:05 -
how to record video directly to usb port on laptop instead memory card...
By foler in forum Capturing and VCRReplies: 1Last Post: 9th Feb 2008, 04:00
