Is there a way to disable the auto detect on project wizard 5/5? With the auto dectect on, i can't lower my bitrates, it insisted on standing at 1600bitrate.
Depends on what template you have selected on the first wizard screen. If you selected anything like VCD, or SVCD, you will not be able to change the bitrate setting in the last wizard screen, in order to stay within spec. Best way would be to manipulate the bitrate yourself manually.
VideoTechManI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
Uh..noo..I've have used some other version of Tmpegnc and i can choose what ever bitrates and sizes i wanted to be.If you selected anything like VCD, or SVCD, you will not be able to change the bitrate setting in the last wizard screen,
and by the way, how do you multiple the bitrate? -
In project wizard 5/5 click the expert button, then go to video tab and click rate control mode(unlock) this will let you change the bitrate. Hope this helps
David -
Default setting....well if you change the bitrate other than 1150 it becomes an non compliant vcd(actually xvcd) I would recomend using 2 pass vbr to get better results, unless you want to make an xvcd and change the bitrate for the amount you want ..there are tons of posts here about bitrates and such about vcds and xvcd's give a search here in the forums.
David
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
auto-detect NTSC or PAL for VHS?
By matt9b in forum Capturing and VCRReplies: 17Last Post: 3rd Jun 2011, 03:28 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 11:06
