  1. Isn't a video that is a mpeg2 format already te correct format for DVD burning or is it just a comparable quality of DVD. Reason I ask is that it seems that it takes so long to convert when trying to author, which I am not having luck with..
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    a dvd can be mpeg2 (it ussually is) ..
    a mpeg2 can be almost any resolution and bitrate but for the mpeg2 to GO ON a dvd it must conform t the dvd specs which are a LOT tighter than the mpeg2 specs ..
  3. Take a look here https://www.videohelp.com/dvd (scroll down a bit). It will tell you which mpeg-2 parmeters need to be within what ranges to be DVD compliant.
  4. MPG2 can also be svcd which is not DVD compliant.
  5. a dvd can be mpeg2
    Doesn't a complaint DVD HAVE TO be MPEG2?
    Mar 2003
    Laredo,Tx
    Originally Posted by LanEvo7
    a dvd can be mpeg2
    look if its an mpeg 2 there are several complient values
    Compliant-352*480, 720*480, or 352*576(pal) 720*576(pal)
    non-Compliant- 480*480, 352*240,
    oh and LanEvo7 to answer your question if your using a DVD-RW you can burn dvd compliant VCDS which are mpeg 1 but you have to change the audio to 48000 instead of 44.1 and im not sure about a header, but i dont have a dvd writer yet. but it would be easier if you just made CVDS my favorite for now till i get my DVD BURNER .
    An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    a dvd can be mpeg2
    no it can be also mpeg1
