  1. How do i ripp a pal dvd and then convert it to ntsc dvd?
    Can dvd shrink do this or if not then what?
    Apr 2002
    Guadalajara, Mexico
    Yep...i wanna know that too. A friend will send me 5 PAL dvd-rs. I don't have problems in read those dvds on my daewoo dvd player (and displaying the image on my ntsc tv), but , as i am a trader, i mostly move my dvds between the north american & japanese communities, so i need ntsc by force.
    I though in play those dvds on my daewoo player and make real-time recording s on my panasonic dmr-e30 dvd recorder, but i'm a bit worried about the quality loss of that procedure.
    Also i can rip the pal dvd & re-encode with the tmpgenc encoder setting the output as a 720x480 ntsc mpg2 file, but also i'll loss a bit of quality, so i don't know what to do. Solutions there are, but if someone knows a better way to convert a PAL dvd to NTSC without lose quality will be very appreciated.
    Big Saludos from Guadalajara, Mexico
    Boulder, Colorado
    Try this trick. I have successfully ripped and converted sereval UK issued DVDs to play on many different US only/ non firmware upgradable DVD players. after ripping the contents to the HD using Smartripper 2.41, i used IfoEdit .95 to remove the region code restriction and replaced the PAL header with NTSC headers. Them Burn them onto a 4.7gb DVD+R. So far have not ran across a DVD player that will not play them.
  4. How do you replace PAL 'headers' with NTSC??
