  1. Hi All
    Long time reader first time poster.
    Just wanna run this past u guys to see if you have any idea. When converting certain divx files they go fine about half way through the video and then the audio slowly starts to go out of sync. By the end of the video it's roughly a minute + out of whack.
    The .avi plays fine. If I convert the audio to a .wav I get the same problem. I've tried to split the .avi and then convert that way however, same problem occurs. And I've noticed that when I split it that at the end of the first the audio plays alittle longer than the video and at the begining of the second video losses that few seconds of audio...
    Any ideas would be much appreciated or if more info is needed please let me know.
  2. How bout if I added this bit of info....
    Audio's bit rate is 129kbs
    and the audio format is MPEG Layer-3
    Video is sitting at 23 FPS
    Data rate is 127 with the sample size 24 bit
    the Video Compression is DIVXMPG4 V3
    Thats the kind of video thats giving me troubles...ideas, questions, comments???
    Please?
    TIA
