I followed the instructions exactly under the "How to convert to SVCD with TMPGEnc" section to convert a DIVX file to an SVCE. I did end up with a playable SVCD. It looks just fine on my PC but when I try to play it on my TV it's like the outer edge is chopped off. This is an anime digisub and whereas the subtitles are about 1/2" up when played on my monitor they are exactly along the bottom of the screen and slightly cut off left and right on the TV. The rest of the outer edge is clipped similarly. Any idea what this newbie is doing wrong? Information appreciated. In the meantime I'll keep searching and trying different encode settings.
Thanks.
This question comes up a lot, but people who have to ask the question don't know what it's called so they can't do a search.... If you do a forum search on "overscan" you'll find more information than you ever wanted on the technical reasons and the ways to work around it.
Ah. Very good. Thank you very much. A few searches with the right keywords (SVCD and overscan) and I'm pretty sure I see what I need to do.
VOBs burned to DVD have sound missing on TV (but play OK on PC)
By martinlest in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2012, 06:17 -
blurred edges
By mathmax in forum RestorationReplies: 50Last Post: 2nd Jun 2010, 10:22 -
Codec missing. Dont know which one. VLC wont play either.
By UmmAddan in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2009, 15:48 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
Vista Media Player 11 doesn't play MP3 Codec Missing
By mlong30 in forum AudioReplies: 6Last Post: 29th Jun 2008, 10:49
