Ok several posts on this forum have convinced me to try ffmpegx instead of mediapipe for converting some of my media files. In regards to the audio sync error i was getting before, i noticed an odd frame rate being reported by ffmpegx during the encode. Is this something normal or is this possibly the root of my problem syncing the audio? I get the following message:
Seems that stream 0 comes from film source: 29.97->24.47
Input #0, mpegvideo, from '/Users/jason/Movies/8_MILE/TITLE01-ANGLE1-VIDEO1.M2V':
Stream #0.0: Video: mpegvideo, 720x480, 29.97 fps, 9800 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0: Video: rawvideo, yuv420p, 720x480, 23.98 fps, q=2-31, 200 kb/s
Where the heck did 24.47 come from??? What consequence does this have on the settings i should use? is my source file fubar perhaps?!
thanks
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
Changing FPS for odd ones is this possible
By SUPERIOR in forum AudioReplies: 4Last Post: 29th Dec 2008, 02:23 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Settings in ffmpegX for odd size .avi files
By sknox in forum ffmpegX general discussionReplies: 2Last Post: 8th Jul 2007, 22:32
