I need help... I can run the program with no problem however when I get to finish page just before selecting output I am having problems..... First of all, I have a 80GB HD partitioned in three sections ( 1 partition (Cis OS, 1 partition (D
is program files and the last is data partition E: ); so when I select "create to disk" it states that I need 6.9GB however my C partition doesn't have that much room left. So I Selected "create dvd folder" or even "create disc image" (separtly) and assigned to my data partition however when I go to output it warns me that C drive doesn't have enough space... I am confused I can't seem to work around this. Any help would be appreciated.......
I don't have MF2 now.... but look for some kind of temporary folder option. Maybe during process MF2 creates some temp file somewhere else.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Check where you have MF2 installed, because if memory serves me correctly, there is a directory called "burntmp" (a temp directory) or something like that. It has a copy of your project in it. So even if you specify the output to another drive, it will keep a copy of it in this temp folder.
Maybe install it on a larger drive, or check in the options and see if you can specify where to put the temp directory. -
I think I found it.....Thanks I will try and keep you guys posted.... It is a temporary working directory.
Thanks again....... -
Follow-up..........I got my earlier video to start converting however after it reached 100% it gave me a failure to convert error, I started out with a mpeg2 file; not to mention 4-5hrs of wait time. But crap.....What a waste of time... I need help figuring this all out.....My experience in DVD author has been a b*tch.........
How is the trial version software automatically disabled?
By coody in forum ComputerReplies: 2Last Post: 25th Nov 2009, 23:35 -
Avid/Pinnacle trial version
By kj1983 in forum EditingReplies: 1Last Post: 28th Sep 2008, 19:31 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 10:25 -
Trial Version of Video Studio 11 hot fix issues, how do I install??
By JediPM in forum Newbie / General discussionsReplies: 8Last Post: 6th Feb 2008, 14:00 -
Using ConvertXtoDVD Trial Version and freezing picture
By DJL82 in forum Video ConversionReplies: 6Last Post: 8th Jan 2008, 18:55
