I've been following Sefy's guide to convert my DVDs to VCDs, but recently I got a new computer, and now my TMPGEnc won't load the .d2v files that I made using DVD2AVI. Is there a codec or something I need to download to make it work? Please help me out, thanks.
Results 1 to 10 of 10
copy the dvd2avi.vfp file from the DVD2AVI folder and place it in the tmpge folder
Just a side note, if you read the troubleshooting section of the guide, you will see i've mentioned specificly to unzip the DVD2AVI to your TMPGEnc location :P
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Which TMPGEnc version do you have ? and which DVD2AVI do you have ?
Best Regards,
Sefy Levy,
OK this is werid no it works. I am using TMPGEnc v2.511.51.160 and DVD2AVI v1.77.3. After maybe between 30 min to 1 hour it worked
OK it looks like I can't open any d2v files anymore in TMPGEnc. I could before and now I can't. In the "VFAPI plug-in" tab in the settings it says that the DVD2AVI preject file reader is there but I still can't open any d2v files. This is really pissing me off
Try Getting DVD2AVI 1.76, i've heard alot of people have issues with 1.77.3
Best Regards,
Sefy Levy,
New to HC Encoder: .D2V files as input?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 09:41 -
Files slow to load in MPC
By MattG in forum Software PlayingReplies: 6Last Post: 15th Sep 2009, 03:29 -
any demuxers other than dgindex create d2v files for avisynth?
By ecc in forum Video ConversionReplies: 3Last Post: 4th Dec 2007, 10:43 -
Error in Gordian Knot when trying to load d2v
By php111 in forum DVD RippingReplies: 12Last Post: 5th Oct 2007, 21:32 -
splitting *.d2v into separate files for xvid conversion
By greenbag in forum Video ConversionReplies: 15Last Post: 22nd Sep 2007, 17:14
