I tried ripping a Friends DVD to VCD, and for some reason the video quality isn't as good. It's more pixelated than the DVD image is. Would that have anything to do with the option to set VCD 1.1 or VCD 2.0? I used the apps in Sefy's Backup Guide: SmartRipper, DVD2AVI, TMPGEnc and VCDEasy.....
Anyone know what I might have done wrong?
Thanks so much in advance!
Look at the description of what a VCD is, on the top of the left navigation bar of this site. The only difference is that VCD 2.0 also supports PAL and have segment items, quality is exactly the same.
What do you mean by "Picture isn't as good", you mean it doesn't look as good as the original DVD? Well, as you probably read (I hope you did
) the resolution of VCD is about a quarter then that of DVD...
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
